AEROFLY ERROR- PLEASE HELP
Moderator
My Feedback: (58)
RE: AEROFLY ERROR- PLEASE HELP
Max, I just wanted to check with you, that during the uninstallation of AFPD, did you delete the IPACS folder as per the instructions at the bottom of the page here http://www.aerofly.com/www/downloads.html ? By deleting this folder, you would have deleted the bad scenery file as well.
Thanks......Mike
Thanks......Mike
My Feedback: (14)
FL
Hi Rajul once I found out that I had a problem with something in the scenery file I deleted the whole scenery file first from my AFPD then I deleted the AFPD and installed it again.....I tried the different standard scerery's that came on the AFPD CD and they all worked fine now with out the error. I then downloaded the one scenery that I like to fly the airfield and now it works fine too. I thank you again for all your help.......Max
