Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
True scale
Old 04-14-2008 | 08:58 PM
rcpete347's Avatar
My Feedback: (251)
Default True scale
HI Mike, I just updated my computer with GeForce 8500GT and more ****m and ended up with 330 frames/sec. In Toledo I bought Real Life and when I put it in the DVD slot , I hear it start to run and nothing, I have Aerofly professional Deluxe 1.11.07.05, I also loaded the patch.
Please help.
Rcpete, PS, the problem with calibrating was finally fixed, by playing with the trims, too finally center the controls,( pretty Micky mouse, if you ask me)
Rcpete, Also I noticed, the new Video card is Direct X10 and before, I had 9x, do I need to download any thing. do I need to download any drivers.
Old 04-15-2008 | 03:50 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: True scale
Hi Pete, I assume that you meant "True Scale"? Did you get any error message when you played the DVD?
Which patch did you load? In general, you should install the addon disk first, then the patch. If this sequence is not followed, try uninstalling/reinstalling AFPD (uninstallation procedure can be found at the bottom of this page http://www.aerofly.com/www/downloads.html ), followed by addon 3.
As for your new graphics card, pls go to the nvidia site and download/install the latest driver.
Old 04-15-2008 | 05:52 PM
rcpete347's Avatar
My Feedback: (251)
HI Mike, I phoned a friend and he told me, the DVD has no opening format and to use Setup.EXE, which I did and the program loaded.
Now the problem I have is it won"t register, I keep getting a error 60225. I have transfered the code on the DVD on True scale, that I bought from Hobby Lobby in Toledo.
The patch which I applied before True scale is 1.11.7.9
So now I have True scale loaded but cann''t register it
Please help.
Rcpete
Old 04-15-2008 | 07:15 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi rcpete, pls follow the activation procedure here http://www.aerofly.com/activate.html The activation code on your disk sometimes may have some characters that may be confusing e.g. a "D" that looks like an "O" etc. So look closely.
Old 04-15-2008 | 09:42 PM
rcpete347's Avatar
My Feedback: (251)
HI, OK I took your advice and it opned the file in Aerofly Professional deluxe, OK now what, how do I find True Scale.
Rcpete
Old 04-15-2008 | 09:51 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi rcpete, there is no need to open the license file. Just drag and drop it into this directory C:\Program Files\IPACS\AeroFly Professional Deluxe The True Scale models and sceneries will be listed in your aircraft selection in the main AFPD menu
Old 04-15-2008 | 09:59 PM
rcpete347's Avatar
My Feedback: (251)
HI, thanks, well I got this far, I"ll have to find out how to drag and drop the file tomorrow night.
Rcpete
Old 04-15-2008 | 10:01 PM
rajul's Avatar
Moderator
My Feedback: (58)
Or you could copy it into that directory, whichever way you prefer.
