Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Transmitter Programing?
Old 08-05-2008 | 09:45 PM
My Feedback: (9)
Default Transmitter Programing?
It was my understanding that if I used a transmitter instead of the game commander that I could use the programming in the transmitter. I noticed in the controller setup that travel and expo can be set, is that the only way to get expo? I couldn't find anything that allowes me to use my dual rate switches either. I'm using a JR 8103.
Also a couple more questions.
Is my X9303 compatible?
Several times I've been to hobby shows and have seen AFPD on big screen TV's. What's the best method to hook it up to my 60" plasma?
Old 08-06-2008 | 07:51 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: Transmitter Programing?
Hi sass, you can set dual rates, expo, and travel from your transmitter. The 8103 and 9303 are compatible but you'll need to get the JR adapter. You'll probably need a long VGA cable to output video from your graphics card to the TV VGA input. Do a search and you'll find how some others have setup theirs.
Old 08-06-2008 | 08:15 AM
I have AFPD and a Sony 50" SRXD 1080P HDTV. My PC does not have PCIe (PCI Express) slots so I am limited to an Nvidia Gforce 6200 video card. It has 256Mb of video RAM and dual DVI outport ports, but it only has PCI slots. The problem is, it does not fully support HDTV, so I had to use a DVI to VGA cable and plug in to the VGA port on my TV, instead of the HDMI port. MY PC is a Pentium 4, 3Ghz, with 2Gb of RAM, but I am limited to 1024x768 resolution, on the TV, and it is somewhat slow. I need to build a faster computer, with PCIe slots, and use something like the Nvidia G8600 or G8800 to get the best performance on my TV
