Electric Helis
CA
When flying an electric heli such as a Trex on AFPD, after a few minutes I run out of power. Is the sim realistically modeling running down of the battery? Is there a way to configure the heli model for unlimited battery/fuel?
CA
Thanks for the reply. I downloaded the T-Rex model from www.rc-sim.de I noticed it also occurs with the Fun Piccolo which I think is a stock model with AFPD.
What models exactly do you mean?? I tried the T-Rex 600 and the original Ipacs Piccolo (there is no Fun Piccolo) and I can't reproduce what you told. How many minutes does it last until you run out of power?
Arthur
Arthur
ORIGINAL: wongtheo
CA
It's the Trex 450 models from www.rc-sim.de. It flies for around 3 minutes then no power. You are right. I am mistaken on the Piccolo model but it exhibits the same affect. Perhaps is my throttle calibration settings on my transmitter getting corrupted in the software?
I flew both models for about 10 minutes without running out of power!
Maybe you have a problem with your radio? Do you have the possibility to use another one for testing it?
Arthur
Arthur
I have a similar problem now Im using my Futaba TX. Even some nitro helis are unale to get off the ground due to lack of power. Maybe its something to do with the throttle hold, I havnt got around to fidling with it yet. Ill post back here once I have a solution.
Dean
Dean
CA
I have the same problem with nitro models. I can only hover above mid stick. At first I thought I had idle-up switched on but I am only using a 4 channel basic Hitec transmitter for the controller. Does the sim have an idle-up feature?
