Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software > Ikarus Aerofly flight simulators
 AFPD and AddOn3 True Scale only. What patch?? >
Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Old 10-30-2008 | 02:03 PM
Default AFPD and AddOn3 True Scale only. What patch??
Hi Mike,
I have AFPD version 1.11.7.9 and AddOn3 True Scale activated. "Both" running fine now, thanks to you.
I have NOT installed any patches yet.
Latest Nvidia driver 175.19 installed 21jul08 to get OpenGL 2.0 so AFPD would run.
My video card: Nvidia GeForce 6200SE with TurboCache 256Mb support, being run at maximum hardware acceleration setting.
I know it's too slow for AddOn3, but, it works ok for now. I will be checking with Kevin my PC man about a faster card.
On the aerofly.com download page this is the latest patch: 1.11.07.21: Fixes a problem with the Beryll model from AddOn 4
I have only AddOn3 installed. No AddOn4 that patch 1.11.07.21 fixes.
1. Should I install this latest patch 1.11.07.21 for AFPD and just AddOn3 ?
2. Or...just install patch 1.11.07.19 since I do not have AddOn4 ?
Thanks and God bless you and yours, Ron
Old 10-30-2008 | 06:24 PM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: AFPD and AddOn3 True Scale only. What patch??
Ron, pls let me know what is the version number printed on your addon3 disk?
Old 11-01-2008 | 08:27 AM
Mike,
My AddOn3 disk version number is 1.11.07.05
1. Is that the latest version of AddOn3??
God bless, Ron
Old 11-01-2008 | 11:09 AM
rajul's Avatar
Moderator
My Feedback: (58)
Hi Ron, you could download the latest patch 1.11.7.21 and run it http://www.aerofly.com/www/downloads.html
Old 11-03-2008 | 10:05 AM
Hi Mike,
I'll install patch 1.11.7.21 and see if I notice anything different.
As I said before, I have AFPD version 1.11.7.9 and have not installed any patches.
The only patches after AFPD vers. 1.11.7.9 is patch 1.11.7.19 and patch 1.11.7.21.
1. If I only install patch 1.11.7.21, do I also get patch 1.11.7.19 changes/fixes as well??
And suppose I buy just addon5, and not addon4.
2. Do I just install addon5 next, as in the order below??
Installation order: 1. AFPD, 2. addon3, 3. patch 1.11.7.21, ....Then...4. install addon5 at the end??
Thanks and God bless, Ron
Old 11-03-2008 | 10:12 AM
rajul's Avatar
Moderator
My Feedback: (58)
Hi Ron, I think addon 5 is likely to be the latest version i.e. 1.11.7.21. So just install it and no need for patches. There's no need to reinstall AFPD or anything else before installing addon 5.
Old 11-03-2008 | 10:27 AM
Hi Mike,
1. So..when I install patch 1.11.7.21,...I also get patch 1.11.7.19 changes/fixes as well. Is this correct???
I do not have addon5 yet and may not get it for several months if I get it at all.
I will install patch 1.11.7.21 as soon as I can.
2. How do I go about installing addon5 when I get it, IF I have already installed patch 1.11.7.21???
Old 11-03-2008 | 10:46 AM
rajul's Avatar
Moderator
My Feedback: (58)
[Yes, that is correct]
[No problem, just install addon5]
Old 11-03-2008 | 11:08 AM
Thanks, Mike.
I thought that was the way it worked. i.e. the latest patch includes "all" previous changes.
Please..correct me if wrong.
And, I thought from reading previous posts (08, 07, 06, etc), that you did not install an addon after a patch.
That you had to uninstall everything and reinstall in this order: AFPD, addon, addon, addon, and then the patch was installed at the end.
I printed the post. I'll dbl ck it. It's been awhile since I read it and I'm probably not remembering correctly.
