Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Usb help
Old 11-03-2008 | 08:22 PM
Default Usb help
Hi mike I am having problems when i start the aerofly program. i get a message stating. Aerofly professional is unable to locate the USB interface cable.Please plug the interface cable into a free usb port. I tried installing it on another computer yesterday and it works fine but i have to get a new gafhics card for that computer. I have tried numerous things all update microsoft has. all the patches aerofly has.Uninstaling and installing the program 3 tome please help me i am about to return this game.
Old 11-03-2008 | 11:29 PM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: Usb help
Hi scuba,
Pls post a photo of the usb interface cable you have. Also, pls provide some information on the following:
Hi,
1) Tell me exactly what kind of hardware you have, especially 3D graphics card, CPU, and any other hardware installed, sound card etc.
2) What is the RAM size?
3) Which operating system are you using, XP or Vista? 32 bit or 64 bit?
4) Tell me exactly what drivers you installed for the 3D graphics card.
5) Which addons do you have?
6) What is the version number printed on your main AFPD disk?
7) How did you install the main disk, addons, and patch (which version?), and what was the sequence of installation?
8) Post the tm.log file which you can find in the following directory
C:\Program Files\IPACS\AeroFly Professional Deluxe
You may open the file with a text editor like word or notepad. Just copy and paste the entire content into your post.
Old 11-04-2008 | 08:30 PM
I have a compac presario V2000. with windows Xp. AMD Turion 64 mobile Technology. Thats all the stuff thats it printed on my laptop. The rest I am not sure .addon ver1.9.1.3 . NTSTATUS
tm: Library Version 4.1, Copyright (C) 1999-2004, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 1040139012
tmsystem: cpu type=(nlogical=1) (nphysical=1) (no hyper-threading)
tmsystem: cpu=797 Mhz
tmsystem: memory=(physical=894MB, avail=554MB) (virtual=2047MB, avail=1753MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 3 (Build 2600) Service Pack: Service Pack 3 (Build 2600)
tmgl: loading font v2 texture/arial10.tmf=(256x256) (32x255) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.8.0.21, Copyright © 1998-2005 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=fail
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
afdesign: init ok
tmgl: loading font v2 texture/menufont.tmf=(512x512) (32x255) ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=800x600) (screen=1280x768) (32bpp) (60Hz) (window)
directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 8000,48000) (12 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=ATI Technologies Inc., renderer=RADEON XPRESS 200M Series SW TCL x86/MMX/3DNow!/SSE2, version=1.4.5014 WinXP Release
gl: (viewport=4096x4096) (texturesize=2048) (stencil=8)
gl: extensions=GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_extensions_string WGL_EXT_swap_control
wgl: extensions=WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_extensions_string WGL_EXT_swap_control WGL_ATI_render_texture_rectangle
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
tmsystem: fullscreen modes=(640x480x16x60) (800x600x16x60) (1024x768x16x60) (1280x768x16x60)
directinput: searching joysticks=none
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=unable to open interface device
tmsystem: searching usb interface (1) 0=unable to open interface device
tmsystem: searching usb interface (0) 0=unable to open joystick device
tminput: 0 devices found
tminput: searching for input devices...(2)
tmgl: loading font v2 texture/arial20b.tmf=(256x256) (32x255) ok
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=1900676 mus
tmcollision: 1604 triangles using 70576 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6)
tmcollision: octmin=(400.0,400.0,400.0)
tmcollision: otnodes=37 otdepth=11
tmcollision: otnmaxareas=838 otnavgareas=48 otnminsize=(312.500,312.500,61.746)
tmcollision: otareas=1801 mem=100856
tmcollision: otclppl=5604 mem=179328
tmcollision: 37 octrees, using 9620 bytes
tmcollision: total mem=360380 bytes
tmcollision: time=48509mus
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 christeneagle...
tmdairfoil: loading naca0015 ok
tmdairfoil: loading flat ok
tmdairfoil: loading naca0009 ok
directsound: register sound sound/g15-3000.wav=ok
directsound: register sound sound/g15-5000.wav=ok
directsound: register sound sound/g15-10000.wav=ok
generating shadow christeneagleshadow0=radius=2.13 bbmin=(-1.28 -1.28 -0.46) bbmax=(1.28 1.28 0.27)
sim: creating blurr=Propeller
tmmusic: off
directsound: shutdown
init window=(window=669x55) (screen=1280x768) (32bpp) (60Hz) (window)
init pixelformat=ok
sim: building rflmaps=(0.00 0.00 0.00) done
tmmusic: off
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
Thanks Carlos PS that is a whole lot of info lots of respect to you I dont understand any thing i just did.
Old 11-04-2008 | 10:14 PM
hey mike I install Flight simulator 4.5 and it the graphics are ok and it is not slow. I know i meet all the recomended hardware. I dont know if this help
Old 11-04-2008 | 10:49 PM
I did some searching in my device manager and I think this is the video card Indeo Intel /indeo video 5.10 commpressor/decompressor. and the usb is Lexors game commander usb
Old 11-04-2008 | 11:36 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi scuba,
Pls post a photo of the usb interface cable you have. Thx
Old 11-05-2008 | 07:01 PM
I dont have a way to put the a pic on here I dont have a camera. I can give you the serial number It come up on my desk top.
Old 11-05-2008 | 07:09 PM
It is the game controller it came with the simulator
Old 11-05-2008 | 11:45 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi scuba, with the game controller plugged into a usb port, pls go to Start....Control Panel....Game Controllers. Pls tell me what you see displayed in the window.
Your RADEON XPRESS 200M video card is also not compatible with AFPD. Pls take a look at the recommended video cards and system requirements here http://www.aerofly.com/www/requirements.html
Old 11-06-2008 | 11:01 PM
ikars gamecommander new hard ware found.
Old 11-07-2008 | 06:23 AM
rajul's Avatar
Moderator
My Feedback: (58)
Your game commander is recognized by windows and is working fine. The problem is probably due to your incompatible video card. Since you have addon 1 or addon 2, you could try installing this patch http://www.ipacs.de/download/afpd190711.exe but it may not help.
