USB commander replacement?
My Feedback: (17)
QC, CANADA
Hello
My lovely daughter played with the AFP commander to roughly and the sticks on the USB commander would need adjustement. Is there a way to repair the commmander or order a new one?
Another solution would be purchasing a JR cable for SIM comm flight cable. What would be the best/cheapest solution?
Daniel
Daniel
Moderator
My Feedback: (58)
Could you describe more specifically the damage to the stick? Is it broken, loose, etc? If you would like to use your JR radio, you could get the usb slave cable and a JR adapter, but you would still need to plug in your GC to a separate usb port as it contains a security chip to enable afpd to work.
My Feedback: (17)
QC, CANADA
I use my sim mostly to practice IMAC and precision flying.
The sticks are not broken but they have a slack at the neutral position. I can not move the sticks by 1/8''without the wanted effect on the plane. I can not screw both sticks on the commander? It looks like they are not enough long to find the bolts into the commmander or the bolts are stripped? If i pull the sticks, they come easily out of the game commander.
Daniel
Daniel
Moderator
My Feedback: (58)
See if you could carefully glue (by medium or thick CA) the stick into place. Otherwise, I would suggest getting the usb slave cable and the AFP-02 JR adapter cable which you can find at the bottom of this page http://www.hobby-lobby.com/aerofly-pro.htm
