AeroFly Pro Deluxe Platinum for Mac OS?
My Feedback: (57)
CA
RE: AeroFly Pro Deluxe Platinum for Mac OS?
Not true according to this: easyFly Modelle / easyFly models
Interesting easyFly models. These models can also be used for AeroFly Professional Deluxe.
Moderator Arthur
Moderator Arthur
#34
all models are compatible with MAC. The problem might be, that the .exe files cannot be installed on MAC PC's. To install a model on a MAC PC you need a zip file. All my models are available now as zip file too at my homepage: http://arthur.heim.at/
The link above goes to the Ipacs-sim.com site and there most of the models are packed in a .exe file. If you want to install such a model, you should contact the creator of the model and ask him for the .zip file.
Best Regards
Arthur
#35
My Feedback: (57)
CA
Arthur,
Thanks for your reply. The model I am trying to use is your Hangar 9 Ultimate which is a zip file which my computer unzips automatically. I have put the files in their respective places, i.e. aircraft and sounds, but they will not show up in the list of Aircraft 1.
#36
Hi simibill,
why don't you use the Hangar 9 Ultimate 2.54m /100" from the AFPD section Motormodelle / Powered models? It's the same and its directly for the AFPD. You can ask RODEO (email: karlheinz.roeder(at)online.de) for a zip file for the AFPD. That would be much better than using an easyFly model.
Regards
Arthur
BTW:
Where did you place the files from the eF zip file? Have a look here how to do: http://arthur.heim.at/faq_ef.html#install_afpd.
Please notice, the zip file does not cintain any preview picture or preview text! If you have installed into the right folders, you will find an entry named H9-ULTI at the end of your model list (see the attached picture).
Regards
Arthur
BTW:
#37
My Feedback: (57)
CA
Arthur,
Thanks for the info. I did put the files as you described. I have found what I guess is the problem. The files with a .tmt extension are supposed to be unix executable files but somehow when unzipped they are shown as documents and don't work.
simibill
simibill
#38
Hi simibill,
I think you should contact Rodeo for the zip file of the real AFPD model. I'm sure he will help you.
Arthur
Arthur
