Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software > Ikarus Aerofly flight simulators
 Arofly for the Mac set up problem/help >
Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Old 04-28-2009 | 06:32 PM
Default Arofly for the Mac set up problem/help
Hello
I need help to set up my Robbe-Futaba FX30 with my brand new Aerofly Profesional Deluxe for Mac.
When I tun on everything a message "searching usb interface, please wait..." appears and stays there for ever. Transmitter is set up to student mode in PPM mode. I have tried with the 2.4 Ghz module installed and uninstalled and no differnece. My soft version is 1.11.07.23. Im using the adaptor cable supplied by Robbe (square to round 3.5 mm female) I have tried the three wire (brown, red, orange) adaptor and it makes no difference.
I have tried my Royal Evo 12 using the Aerofly supplied adaptor and no difference, it does the same thing. It seams that the problem is with the USB adaptor and not with the transmitters. Is there something else I need to do to have my mac talk to the USB adaptor and eventually with the transmitter?
Thanks a lot in advance for your help.
Best regards
Felipe
Old 04-28-2009 | 06:40 PM
exeter_acres's Avatar
Default RE: Arofly for the Mac set up problem/help
is your transmitter in PPM mode?
Old 04-28-2009 | 07:04 PM
Yes, both the Robbe-Futaba and the Multiplex are set up at PPM, and both are at student mode.
Felipe
Old 04-28-2009 | 07:25 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi Felipe, pls post a photo of the usb interface cable and adapter cable that you have.
Also plug in your usb interface into any usb port and do the following:
Click the Blue Apple in the top left corner.
Click About This Mac .
Click More Info... .
Under Contents on the left side click USB .
Verify type of Ikarus device listed under the USB Device Tree on the right side.
Old 04-29-2009 | 07:15 AM
Felipe and Mike,
Is it already availabl in the US? How did you buy it, Felipe?
Thanks!
Flavio
Old 04-29-2009 | 09:51 AM
Hello Flavio,
I ordered through the web and came by mail from Germany, only 8 days from Germany to Mexico, excellent service.
Last night I install it on a different mac, and so far the USB interface is working. So I guess my problem is on my MacBook Air somehow. Tonight Ill connect my transmitter and see how it works.
Best regards
Felipe
Old 04-29-2009 | 10:47 AM
Felipe,
Thank you for the information.
PLease, accept my sympathy regarding the virus problem you guys are going through.
Best regards,
Flavio
