Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
How to delete edited models?
Old 08-09-2010 | 10:12 AM
Default How to delete edited models?
How do I delete edited models? Where, how are these settings and or files located? I completley uninstalled and then reinstalled afpd but the edited planes are still there. Thanks, David.
<span class="info"> </span>
Old 08-09-2010 | 11:19 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: How to delete edited models?
David, go into the main AFPD directory and you will find a folder called "aircraft". Open that folder, find the edited model names and delete them.
Old 08-09-2010 | 11:23 AM
I tried that first and then I completley uninstalled and then reinstalled afpd but the edited planes are still there. That did not work. Thanks, David.
Old 08-09-2010 | 12:03 PM
rajul's Avatar
Moderator
My Feedback: (58)
That should not be the case unless a complete uninstallation was not done. In any case, you do not need to do an uninstallation just to delete model files, just follow the procedure I mentioned earlier. Did you log into your PC as an administrator?
In case you need to do an uninstallation, please follow the uninstallation procedure at the bottom of this page http://www.aerofly.com/afpd/downloads.html but this is not necessary for what you intend to do, just an additional info
Old 08-14-2010 | 02:10 AM
Thanks Rajul,  Your answer is correct and appreciated. David
Old 08-15-2010 | 08:53 AM
rajul's Avatar
Moderator
My Feedback: (58)
Dave, you're most welcomed!
