Aerofly Platinium Deluxe
I've been having AFPD for about 3 years. I haven't played about a year and tried to play yesterday. It says my USB is not connected. I've upgraded my OS to 10.7.5 last year. I'm using DX7 with JR adapter. I've notice the serial number is gone on the main page. It just says #####. Any help will be appreciated.
RE: Aerofly Platinium Deluxe
It could be that your usb interface has gone faulty but let's do some software check first. Which AFPD version do you have? You could see the AFPD version number in your startup screen.
I have version 1.11.07.31
1 Attachment(s)
This is what I have.
Please copy the entire content of your tm.log file, which you can find in the AFPD folder, and paste it here. Thanks
tm: Library Version 4.2d, Copyright (C) 1998-2009, IPACS
tm: http://www.ipacs.de openal: init structs openal: init (default=Built-in Output) (0:Built-in Output) (using default device) (version=1.1) (1.1) (Built-in Output) (Built-in Output) ok tmsystem: mac os version=10.75 loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok tmgl: loading mouse texture/mouse.tmt=ok tmprogram: AeroFly Professional Deluxe Version 1.11.07.31, Copyright (C) 1998-2009 IPACS loading configfile config/main.mcf=ok loading player configfile config/player1.mcf=ok loading player configfile config/player2.mcf=ok openal: register sound sound/beep.wav=(0, rd=100.00) ok openal: register sound sound/balloon.wav=(1, rd=100.00) ok openal: register sound sound/crash.wav=(2, rd=100.00) ok openal: register sound sound/splash.wav=(3, rd=100.00) ok openal: register sound sound/glider.wav=(4, rd=2.00) ok openal: register sound sound/glider2.wav=(5, rd=2.00) ok openal: register sound sound/glider.wav=(already registered)(6, rd=5.00) ok openal: register sound sound/glider2.wav=(already registered)(7, rd=5.00) ok openal: register sound sound/glider.wav=(already registered)(8, rd=2.00) ok openal: register sound sound/glider2.wav=(already registered)(9, rd=2.00) ok openal: register sound sound/glider.wav=(already registered)(10, rd=5.00) ok openal: register sound sound/glider2.wav=(already registered)(11, rd=5.00) ok afdesign: init ok gl: vendor=NVIDIA Corporation, renderer=NVIDIA GeForce 8800 GS OpenGL Engine, version=2.1 NVIDIA-7.32.12 gl: (viewport=8192x8192) (texturesize=2048) (stencil=8) gl: extensions=GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod gl: extensions=(anisotropic filter of 16.00) (compressed texture) (cubemaps) (shader) (framebuffer) framebuffer object created (1024, 1024) framebuffer object created (256, 256) tminput: searching for input devices...(3) tmsystem: searching usb interface (0,0) 0=ERROR: iohidmanagercopydevices failed unable to open interface device tmsystem: searching usb interface (1,0) 0=ERROR: iohidmanagercopydevices failed unable to open interface device tmsystem: searching usb interface (0,1) 0=ERROR: iohidmanagercopydevices failed unable to open joystick device tmsystem: searching usb interface (1,1) 0=ERROR: iohidmanagercopydevices failed unable to open joystick device tminput: 0 devices found sim: loading scenery scenery/pagefield.geo... sim: 1 objects 0 dynobjects sim: start position 1 (not for helicopter) sim: start position 2 (not for helicopter) sim: start position 3 (not for helicopter) sim: start position 4 (not for airplanes) sim: start position 5 (not for airplanes) sim: ballons=10 (-10.00,-7.00,2.00) (-24.00,7.00,6.00) sim: dragrace=(100.00,270.00) sim: spotarea=(25.00,14.00) sim: load texture grid 5x5 (pano=0) (compress=1) named pagefield/pagefield=(3.600x4.000) (5x5) (20x10) sim: sphere params(0)=0.0000 0.0000 110.0000 sim: loading ground object scenery/pagefield/pagefield.obj=ok sim: loading time=1386821 mus sim: 1 photo scenes tmcollision: 7361 triangles using 942208 bytes tmcollision: omin=(-2333.1,-2579.2,-1.9) omax=(2492.3,2272.8,31.4) octmin=(30.0,30.0,30.0) tmcollision: otnodes=343 otendnodes=172 otdepth=17 otlistareas=120819 tmcollision: otnmaxareas=341 otnavgareas=50 otnminsize=(18.849,18.953,16.637) tmcollision: otareas=8749 mem=977204 tmcollision: 343 octrees, using 52136 bytes tmcollision: total mem=1029340 bytes tmcollision: time=0.03s tmcolldynamic: no dynamic objects or triangles sim: loading aircraft 1 da40... tmdairfoil: loading naca2314 ok tmdairfoil: loading naca0015 ok openal: register sound sound/aztec.wav=(12, rd=5.88) ok openal: register sound sound/aztec2.wav=(13, rd=5.88) ok openal: register sound sound/aztec2.wav=(already registered)(14, rd=5.88) ok generating shadow 0=radius=4.39 bbmin=(-2.20 -2.20 -0.44) bbmax=(2.20 2.20 0.42) sim: creating blurr=Propeller saving configfile config/main.mcf=ok saving player configfile config/player1.mcf=ok openal: shutdown=ok |
Thanks for the tmlog file. Are you a user in mac os x with limited rights or do you have admin privileges?
Are you connecting the usb interface cable through a usb hub or directly to a native usb port in the computer? Do you have another computer where you can test the usb interface cable? |
Yes, Mac OS X
Admin privileges Connected straight to the computer. Yes, I have a laptop but its windows. |
Please do the following tests and see if the usb interface is recognized in AFPD:
- Remove all other USB devices, especially PDA docking stations or scanners and try again. - Use another USB port on your computer. Then please plug the usb interface into your windows laptop. Go to control panel->hardware and devices->devices and printers. Do you see "Ikarus interface"? |
1. Removed all usb devices on Mac. Nothing happened. Still does not work.
2. Plugged on Windows computer and went into device and printer. Nothing showed up. |
Please try to reset your PRAM as per the instructions here:
https://discussions.apple.com/thread...art=0&tstart=0 |
Tried the PRAM twice. Still the same.
It's confirmed that you have a faulty usb interface. Unfortunately your interface is outside of the two-year warranty. Please contact Frank of Ikarus USA (contact details below) for an exchange. The exchange pricing for outside warranty interface is $29.95 plus S&H 8.95. You will get the new type usb interface that looks like a thumb drive. You could also check with Frank on the AFPD to AF5 upgrade, which I would recommend.
E-Mail: [email protected] Internet: www.ikarus-usa.com Phone: +1 239 540 0067, Ext.1 Mo-Fr 7:00 am to 6:00 pm |
Ok, thanks. I will do that.
