AFP wont recognize the commander
My newly installed AFP will not recognize the commander, only the 9-pin interface cable. The computer sees the commander and I can calibrate it as a game input. Therefore I can not use AFP!!!!!!!!!! What can I do?????????
RE: AFP wont recognize the commander
Do you have them both plugged in at the same time?
I have tried it both ways.
1) when both are plugged in at the same time, it only recognizes the 9-pin 2) when only teh 15-pin commander is plugged in, the computer sees it, but AFP does not. 3) when only the 9-pin is connected, all is well other than having to turn my TX on. Wont work with my TX off. Thanks for any help you can provide. |
For starters they must both be plugged in.
However these cables are on seperate ports, they should not interfere with one another. The question that I have is that this is newly installed Commander version. The Commander version has been out of stock for some time. Did you purchase it from a friend? Which radio are you using. |
1) Using a Futaba 6TXH.
2) I purchased it last week from my local hobby shop. I assumed it was a new version as they have been out of stock for a while and now have them again. How can I tell? 3) When both are connected at the same time it only recoginizes the 9-pin. Hopefully we can get this sorted out. Thanks. |
Are you running windows XP?
You have the first version of AFP with Commander. There is a new version coming with Commander. It's AeroFlyPro Deluxe. |
No, windows ME.
Correct, I have Aerofly Pro, NOT Deluxe. |
Well the serial port and 15 game port are 2 different ports. The problem is that they are sharing IRQ's most likely, this is a Window's sharing issue.
You need to diagnose the ports and assign them their own IRQ's. |
| All times are GMT -8. The time now is 11:39 PM. |
