AFPD Add-On 5
Gentleman,
I have AFPD with everything working properly. I just tried to install Add-On 5 and not only didn't the install go well, But I can't get any of AFPD to work. I keep getting a "main executible has stopped working" message. I am running Vista with Add-Ons 1, 2 & 4 as well as Starflight. Any ideas as to what the problem is? Update: I just did a removal of Add-On 5 not only did Add-On 5 not work, the previous set-up without Add-On 5 no longer works Thanks Charlie |
RE: AFPD Add-On 5
Hi Charlie, could you tell me in which directory did you install AFPD and Addon5? Which video card are you using? Pls post your tm.log file which you can find in the AFPD directory. You may open the file with a text editor like word or notepad. Just copy and paste the entire content into your email. Thanks
RE: AFPD Add-On 5
Mike,
Installation is in C:/Program Files/IPACS/Aerofly Professional Deluxe. Video card is Nvidia GeForce 8500GT. The tm.log file is blank I removed all the Aerofly files and reloaded the program along with Add-ons 1, 2 and 4 as well as upgrading to version 1.11. Everything worked fine. I tried reloading add-on 5 and the program crashed again I tried loading the Program in D: directory. no luck there. Just tried reloading the program in the C: directory and now I can't get anything to work. Thanks Charlie |
RE: AFPD Add-On 5
Hi Charlie, did you follow the uninstallation procedure given at the bottom of this page http://www.aerofly.com/www/downloads.html ? Can you check the version number printed on your main AFPD disk? Thx
RE: AFPD Add-On 5
Mike,
Version 1.8.0.21 I've got the basic program running again with Add-Ons 1 & 2 which took it to Version 1.9.7.11 Charlie |
RE: AFPD Add-On 5
Hi Charlie, the sequence of installation should be main disk...addon1....addon2....addon3.....addon4.....a ddon5....patch 1.11.7.21
RE: AFPD Add-On 5
Mike,
Used the sequence shown above. Added add-on 4. It raised the Version to 1.11.7.7. Ran the program and everything worked. Added Add-On 5 and ran version 1.11.7.21 and the program crashed Charlie |
RE: AFPD Add-On 5
Hi Charlie, did you get any error message?
RE: AFPD Add-On 5
"Aerofly Professional Deluxe main executible has stopped working" message
RE: AFPD Add-On 5
Thanks Charlie, pls try installing until addon5 without any any patch. Pls follow the uninstallation procedure I gave above. Thanks
RE: AFPD Add-On 5
Will do
RE: AFPD Add-On 5
Removed program per instruction. Reloaded. Eveything ran up through Add-On 4.
Loaded add-On 5. Program crashed |
RE: AFPD Add-On 5
Hi Charlie, thanks for the confirmation. Let me figure this out and get back to you on Mon. Thanks
RE: AFPD Add-On 5
Mike,
Sounds Good Thanks Charlie |
RE: AFPD Add-On 5
Hi Charlie, Pls post your tm.log file which you can find in the following directory
C:\Program Files\IPACS\AeroFly Professional Deluxe You may open the file with a text editor like word or notepad. Just copy and paste the entire content into your post. Thx |
RE: AFPD Add-On 5
With everything reloaded up thru Add-On 4 and Version 1.11.7.7 the File is blank.
RE: AFPD Add-On 5
Hi Charlie, if your tmlog file is empty it is an indication that you have installed in the wrong directory. Can you tell me how you installed AFPD, the addons, and the patch? Did you install them automatically, or did you install them into a certain directory? Did you disable UAC (user account control) in Vista?
RE: AFPD Add-On 5
Mike,
Auto at first and second install attempt, then manually, then auto for the last install thu add-on 4 I just tried to install Add-on 5 with UAC off and the program crashed Charlie |
RE: AFPD Add-On 5
The newer disk version 1.11.x.x installs into the correct directory in vista automatically, but not the older versions like 1.8.x.x As such pls try to install the main disk, the addons and patch in vista using the procedure which you can download here http://www.aerofly.com/ipacs_vista.pdf Disable the UAC too
One more thing is that since you're installing Addon 5, there is no need to install any patch anymore. So, just install the main disk and addons in sequence to the correct directory as per the instructions |
RE: AFPD Add-On 5
Mike,
Did the delete and reinstall per instructions. With UAC off I could get to the point of registering, but kept getting an error message that the number was invalid. I had to turn the USC on again to log in here, and when I did the program crashed again Charlie |
RE: AFPD Add-On 5
Hi Charlie, which registration number is this? Are you the administrator of the system?
RE: AFPD Add-On 5
Mike,
The Add-On 5 Product Key. The screen already displayed the base program serial number Yes, I am the admin |
RE: AFPD Add-On 5
Hi Charlie, you should download the license file for addons 3, 4 and 5 and put it into the new AFPD directory. The license files need to be in this directory for the Addon program to recognise it. You could use this link to download the license files http://www.aerofly.com/activate.php?lang=en
RE: AFPD Add-On 5
Mike,
Downloaded the license files and after some manipulation, it now appears to be working. Thanks for all your help Charlie |
RE: AFPD Add-On 5
Hi Charlie, OK good to know that all is fine now. Enjoy!
| All times are GMT -8. The time now is 08:46 AM. |
