Go Back  RCU Forums > RC Airplanes > IMAC
 Pefa 2 into one Muffler >
IMAC Discuss IMAC style aerobatics in here
Old 09-30-2003 | 10:03 AM
Randy Brown's Avatar
Default Pefa 2 into one Muffler
Hi di ho
I am looking for informatoin on the Pefa 2 into 1 exhaust like jason has on his webpage
http://www.jasonshulman.com/extra.html
I cannot find any online info.. unless anyone happens to know the new pefa webpage adddy because the one I have does not work
Randy
Old 09-30-2003 | 10:54 AM
RightThrust's Avatar
Default RE: Pefa 2 into one Muffler
Call DA, they should be able to help you. I hear 2-1 can systems have problems with surging. But, like I said, DA should be able to answer your questions.
-Kelly
Old 09-30-2003 | 10:57 AM
Its long distance
Actully waiting for a email reply RT
Who said the internet is faster
Old 09-30-2003 | 11:53 AM
Flyfalcons's Avatar
I have seen a 2-1 cannister system with a DA-100. Seemed to work pretty well, although the engine wasn't quite as steady at low RPM than an engine with stock mufflers. It was quiet though - all I could hear was the prop noise.
Old 09-30-2003 | 02:58 PM
My Feedback: (31)
I used the 2 into 1 with a DA-100 installed in a Fiber Classics 2.6M Extra. For whatever the reason it was not RIGHT! Idle surged and transition was not all that, I was told by Dave Johnson and several other engine reps this had been a commonplace occurence. It might have something to do with the header length, just guessing. BUT your limited in this model as with most. I gave up and pulled the cannister. I even swapped out engines with a known good running unit to no avail.
I'll bet you won't find a truly satisfied user with this combination.
http://www.pefa-modelltechnik.de/
