Dual elevator servos in Goldberg Sukhoi
My Feedback: (82)
OH
Hi all,
I am using dual elevator servos in my goldberg sukhoi which is on my building board at the moment. I want to find the best servo I can, and I think it has to be a "mid" servo (not as tall as a standard servo) in order to fit into the tail. What futaba or JR servos are there that you guys recommend. I will be using the sukhoi for getting into IMAC (basic first) and then move up from there. Even though I will be a beginner in IMAC, I still want to use the best mid servo for the job.
Chris
Chris
I'd use the JR 9411 Digitals. Mid size coreless-- 82 oz. torque at 4.8V
You could try the JR 7005 coreless, but I'd be afraid the gears weren't strong enough. I had a pair that I was going to use on my elevators of my 27% Extra. I took the cases apart and looked at the gears, then decided to use the JR 8231. Not a mid size servo- but 88oz. torque and bigger gears than the 7005.
Also look at the JR 911 servo. It's a mid size 5-pole motor. Better than analog, but not quite as good as a coreless servo. I'm usung them on a 40 size 3D, but it's OVERKILL at 6V. They are 42oz. at 4.8 V
Also look at the JR 9011 mid coreless. 60oz. torque at 4.8V.
Try this link. I've got it saved in my favorites. It lists almost all the current JR servos. Not always the cheapest place to buy them, but a good reference when searching for the right servo for a given application.
http://www.centralhobbies.com/radios.../JRservos.html
Stick with the JR servos-- your plane will last longer. I tried Hitecs on a couple of planes. Got the toothpicks in the landfill to prove it.
My Feedback: (16)
GA
I stand corrected.
You can go with a lower torque than I recommended if you use a digital servo because the digital can created more torque from a smaller error signal.
ORIGINAL: Geistware
I would use hitec 5975 servos
