HELP programming 9z for IMAC
IN
Can any of you guys help me with my 9z programming?
Does the 3 dual rate circuits a,b,c only work on one surface at a time....ie a is elev, b rudder etc?
My afr no longer seems to work I have 2 conditions patt and 3d and when I went to reduce the 3d rudder movement (AFR?) it would not have any effect...............do you get AFR OR dual rate?
Obviously I would like to call someone who flies IMAC with a 9z to get sorted out so if any of you guys are willing to put up with my stupid questions I would be forever in your debt.
I am in the Indianapolis area
Kindest regards IanB
CA
This should help Ian http://www.futaba-rc.com/faq/faq-9z.html I usually use different conditions, that way you could have many different rates on each servo. There are a couple ways to accomplish multiple rate.
