Go Back  RCU Forums > RC Airplanes > IMAC
 2005 sequences are now avalable........ >
IMAC Discuss IMAC style aerobatics in here
Old 12-03-2004 | 08:41 AM
My Feedback: (8)
Default 2005 sequences are now avalable........
the final 2005 sequences have just been released . Go to IMAC website and use the pull down select box on the top left hand side of the home page. Just select your category and hit go.... Good luck everyone . Looks like 2005 will be a Busy season....
http://www.mini-iac.com/DesktopDefault.aspx
Old 12-03-2004 | 10:46 AM
Silent-AV8R's Avatar
Default RE: 2005 sequences are now avalable........
Here's some help with Aresti if anyone wants it:
http://www.scaleaerobatics.org/downl...MadeSimple.pdf
http://www.scaleaerobatics.org/downl...estiPrimer.pdf
And finally, the FAI Catalog itself:
http://www.fai.org/aerobatics/catalog/
I think anyone who spends about 15 minutes with the first two references
above should be able to read any Basic through Intermediate Aresti fairly
easily.
Old 12-03-2004 | 11:08 AM
My Feedback: (34)
Yep.. now that the sequences are final, it's time to put the politics and arguments aside and start burning gas!
Old 12-03-2004 | 05:20 PM
Just going from memory, it looks like the Unlimited sequence has changed a little from the two proposals..
No biggie. Just an observation.
Old 12-03-2004 | 05:33 PM
My Feedback: (19)
why is it i cannot pull up the sequences...i could yesterday,but not now??
Old 12-03-2004 | 06:31 PM
ORIGINAL: wgeffon
It did. The IMAC BoD mades some changes based on feedback from their group of sequence test pilots. I am NOT looking forward to judging this sequence. Not sure any judge will really be able to keep up with it. Nasty busy in my opinion.
Old 12-03-2004 | 08:09 PM
My Feedback: (19)
has anybody tried looking at the sequences tonight...am i the only one who is having trouble pulling them up??
Old 12-03-2004 | 08:27 PM
John Murdoch's Avatar
330.. Nope. Not a problem here. I just brought up Advanced and Unlimited...
Old 12-03-2004 | 08:47 PM
I like the Intermediate sequence better than the proposal.
A lot of inverted to inverted maneuvers, looks harder than last year's sequence.
Old 12-03-2004 | 11:41 PM
My Feedback: (19)
OK,WHAT GIVES!!!!!!I DOWN LOAD ADOBE 6.0 FROM MY 4.0 VERSION...TRY TO PULL UP THE SEQUENCES,AND SAYS THE FILE IS DAMAGED AND COULD NOT BE REPAIRED....SO,DID THE ADVANCED SEQUENCE CHANGE AT ALL??AND WHICH VERSION DID IT GO WITH??THANKS.
Old 12-03-2004 | 11:50 PM
RightThrust's Avatar
Hey Joe, it's Kelly Gerber. That happened to me too. What you've gotta do is when you get that error just click GO again on the URL and then it came up for me. Or you can copy and paste the URL again into the address window and see if that works. Hope to see you around some contest's next year!
-Kelly
Old 12-03-2004 | 11:56 PM
My Feedback: (19)
Kelly,whats up!!!dude,i tried it again,uninstalled and installed again,tried what you suggested several times,still no luck...it just keeps saying the same thing...file is damaged and could not be repaired,this really @!#$'%
Old 12-04-2004 | 12:18 AM
My Feedback: (19)
kELLY,TRIED THE WHOLE PROCESS AGAIN,AND IT CAME UP...FINALLY.I will see you next year at alot of the contest's.I got my 40%being built,and should be ready for the JR Challenge,i am also going to make some of the Fla. contest...i need to make up for this year,only making two contest really is a bummer...but i am really anxious for this up coming year,congrats on your regional win,but sorry for the mishap with your Extra,we'll see you soon,Joe
Old 12-04-2004 | 12:43 AM
rmh's Avatar
rmh
The Unlimited is flyable -obviously - I stick flew it but I really did not want to see the end of box ,outbound maneuver which will likely place maneuver 4 in the next county.
Sure - the line from left to right can be shortened up -but then it really gets busy looking.
Other than that - It can all stay within reasonable size .
Thanks for the time and work tho - I know sequence development is sometimes a thankless job.
Now if I can only get time to finish my own planes --
Old 12-04-2004 | 09:31 AM
My Feedback: (12)
I'm wth you Diablo. I like the final a little better. I especially like the snap instead of the 2 point on manouver 1.
Ryan
