Go Back  RCU Forums > RC Airplanes > IMAC
 Servos for 24% Colombo >
IMAC Discuss IMAC style aerobatics in here
Old 01-11-2005 | 11:31 PM
Default Servos for 24% Colombo
I am planning on running my servos on 6V. This is an electric conversion that will weigh 10 1/2 pounds AUW. I am using it for IMAC basic class. I am thinking one JR 9411SA per aileron. The elevator I am planning on using D.E.P.S. from Central hobbies and one 8411SA, this should help with balance. Now the rudder is one 8411SA enough or should i go for a 8611 it is a Pull-Pull. The manual uses some Kg for servo torque. Thanks this my first step out of 40s and digital servos.
Old 01-11-2005 | 11:39 PM
flyintexan's Avatar
Default RE: Servos for 24% Colombo
For what it's worth, I have 120oz-in. on the rudder (6v) on my extra and have not felt any push-back...
I have the same on the elevators (single servo) using a pull/pull setup...I wish I had setup the DEPS from central instead...
