Go Back  RCU Forums > RC Airplanes > IMAC
 will it work / >
will it work /
IMAC Discuss IMAC style aerobatics in here
will it work /
Old 07-20-2005 | 02:10 AM
Default will it work /
just purchased an 87" edge 540T on ebay .
don't have a 50 but I do have a 40 cc
the plane is supposed to weigh in at 15 Lbs.
will a 40 work ???
thanks guys
Old 07-20-2005 | 05:10 AM
3D Joy's Avatar
Default RE: will it work /
I just test flew a CA model Extra 27% at 15 lbs with a ZDZ40. The plane flew very nice with good power. Now the CA model is a much smaller plane than the one you are considering...
Old 07-20-2005 | 06:49 AM
rmh's Avatar
rmh
Unless you have a good exhaust setup -read that , a tuned system, it will require all the poop you can muster..
Even with low weight -the increased drag of simply being larger -will get you.
