Go Back  RCU Forums > RC Airplanes > IMAC
 Detailed sequence explanations? >
IMAC Discuss IMAC style aerobatics in here
Old 04-04-2006 | 11:27 PM
Default Detailed sequence explanations?
Is there anywhere I can go that details the manuevers in the various IMAC sequences - something that explains the diagrams? As a newbie, I can't make heads or tails of the diagrams of the various schedules on the IMAC site.
Thanks.
Old 04-04-2006 | 11:44 PM
Default RE: Detailed sequence explanations?
there are several written discriptions on here somewhere. but i see you live in the NC region, come to the NC judging seminr the last week of april. you'll learn everything you want to know, and more. its very well done, and lots of fun. but keep looking on here for them.
brian
Old 04-05-2006 | 12:38 AM
www.mini-iac.com has an Aresti learning guide.
This years sequences are:
Basic:
1- One roll from upright to upright.
2- Pull to Vertical, pull half inside loop, 1/2 roll on the vertical downline, pull to upright exit.
3- Pull to 45, 1/2 roll, pull 5/8 inside loop, exit upright.
4- Pull inside loop.
5- Pull vertical, stall turn, vertical downline, pull to upright exit.
6- Pull 45 upline, 1/2 roll, pull to vertical downline, pull to upright exit.
7- Pull vertical, pull 3/4 inside loop, exit upright
8- Pull 5/8 inside loop to a 45 downline, 1/2 roll, pull to upright exit.
9- Pull 1/2 inside loop, 1/2 roll, exit upright.
10- 1-1/2 positive spin, pull to exit upright.
Sportsman:
1- Pull vertical, 2 points of an 8 point roll, Stall turn, vertical downline with a 3/4 roll, pull to upright exit.
2- straight line, 1/2 roll to inverted, push 5/8 outside loop to a 45 downline, 1 positive snap, pull to upright exit.
3- Pull 1/2 inside loop, 1/2 roll, exit upright.
4- 1-1/4 positive spin, exit upright cross box.
5- Pull to vertical. 2 points of a 4 point roll, push 1/2 outside loop, vertical downline with 1/4 roll, pull to upright exit.
6- Pull to vertical upline, One roll, Pull to inverted exit.
7- From inverted, 2 point roll back to inverted, pull 1/2 inside loop, exit upright.
8- Pull 1 inside loop with one full roll at the top, exit upright
9- Pull 135 degrees to a 45 upline, 2 points of a 4 point roll, push to upright exit.
10- From upright, 1/2 roll to inverted, pull 3/4 inside loop to a vertical upline, 3/4 roll, push to upright cross box exit.
Intermediate:
1- Pull 7/8 inside loop to a 45 degree downline, 1/2 roll, push to inverted exit.
2- Push to a 45 degree upline, 2 point roll, push 5/8 outside loop to a vertical downline, one positive snap, pull to upright exit.
3- Pull vertical upline, pull to a 45 degree downline, 4 points of an 8 point roll, pull to upright exit.
4- Pull vertical upline, 1-1/2 rolls, Stall turn, vertical downline, 2 points of a 4 point roll, pull to upright exit.
5- Pull to 45 upline, 1 roll, push to a vertical downline, 1/4 roll, opposite direction 3/4 roll, pull to upright exit.
6- Pull to vertical upline, 3/4 roll, pull 1/2 inside loop (X-box), Vertical downline with 1-1/4 rolls, pull to upright exit.
7- Pull to 45 upline, 1 positive snap, push 3/4 outside loop to a 45 degree upline, 4 point roll, pull to inverted exit.
8- Pull to a 45 degree downline, one negative snap, pull 1/2 inside loop to a 45 degree upline, 1 roll, push to upright exit.
9- 1-1/4 positive spin, exit cross box upright.
10- 1 roll to the inside of a 90 degree heading change, exit upright.
Advanced:
1- Pull to vertical, 3 points of a 4 point roll, stall turn, vertical downline with a 2 point roll, push to inverted cross box exit.
2- From inverted, 270 degree rolling circle with 3 rolls to the inside, exit inverted.
3- Push to a 45 upline, 1 roll, push to upright exit.
4- Push 1/2 outside loop, 1/2 roll, opposite direction 1 positive snap, pull 1/2 inside loop, exit inverted.
5- Pull to a vertical downline, 3/4 roll, opposite direction 3/4 negative snap, Pull to a 45 degree upline, 3 points of a 2 point roll, pull to inverted exit.
6- 1-1/2 negative spin, push to inverted exit.
7- Push to vertical upline, 1/4 roll, opposite direction 1 positive snap, Pull 1/2 inside loop (X-Box), vertical downline, 1-1/4 negative snaps, pull to upright exit.
8- Pull to 45 upline, 1 positive snap, opposite direction 1/2 roll, Pull 3/4 inside loop to a 45 upline, 1/4 roll, opposite direction 3/4 roll, pull to inverted exit.
9- Pull to a 45 downline, 1-1/2 negative snaps, pull 1/2 inside loop to a 45 upline, 1-1/2 rolls, push to upright exit.
10- 1-1/2 positive snaps, pull 1/2 inside loop, 8 point roll, exit upright.
Unlimited:
1- Pull 135 degrees to a 45 upline, 2 points of a 4 point roll, opposite direction 2 point roll, push to a vertical downline, 1 negative snap, push to inverted exit.
2- Push to a 45 upline, 3/4 negative snap, opposite direction 3 points of a 4 point roll, pull 3/4 inside loop to a 45 upline, 1-1/2 rolls, pull to inverted exit.
3- 1 roll, pull 1/2 inside loop, 8 point roll, exit upright.
4- Pull vertical, 1-1/2 negative snaps, stall turn, vertical downline with 1 positive snap, opposite direction 1/2 roll, pull to upright exit.
5- Pull vertical upline, 3 points of a 2 point roll, pull 3/4 inside loop with 1 positive snap on top, 2 points of a 4 point roll, exit inverted.
6- 1-1/4 negative spin, vertical downline, 1/2 inside loop (X-Box), vertical upline, 6 points of an 8 point roll, push to upright exit.
7- Push to vertical downline, 2 point roll, pull to a 45 dgeree upline, 1 roll, push to a vertical downline, 2 negative snaps, push to inverted exit.
8- From inverted, 180 degree heading change with 1 roll to the inside, 180 degree heading change with 1 roll to the outside, exit inverted.
9- Push to 45 upline, 1 roll, opposite direction 1/2 roll, push 5/8 outside loop,1 negative snap, exit inverted.
10- 3 points of a 4 point roll, opposite direction 1-3/4 positive snap, exit inverted.
Old 04-05-2006 | 06:39 AM
My Feedback: (37)
Wayne,
Very nice! I had to make a few copies of that for myself to hand out to some new pilots in our club.
Bob,
There are a few guys from the area going to the Judging Seminar in Muncie later this month as Brian mentioned. It is not a required seminar to fly IMAC, but it sure does help. If you would like to go let me know, we can ride together or follow each other.
The first IMAC contest in Michigan is being held in May just down the road from you. It is actually my clubs contest. We will be having a few practice days before the contest for those that want to join in the fun, you are of course welcome to be there. We do not actually have a practice day scheduled yet, but I am sure there will be very soon......it needs to warm up a bit.
Brian,
Hope to see you before Muncie, practicing at our field. I'll let you know the date and time later.
Tim Wieber
Old 04-05-2006 | 07:21 AM
if you do a search i wrote a relatively detailed description of the basic sequence a few months ago.
P
Old 04-05-2006 | 08:49 AM
Thanks everyone. Wayne - thanks for putting that info out here... I missed it on that site somehow. Appreciate your help.
Tim - thanks for the info. I noticed the events around the state and I'm surely going to try and make as many as I can, especially the one at your field - I figure it's under an hour away. That seminar at Muncie really looks sweet and I'd love to go. I'll have to think about it as it's hard to break away for an entire weekend with family and work.
