Hanger 9 Extra 260 with Fuji 43 EI
WI
I am looking for some opinions about using the Hanger 9 Extra 260 with a Fuji 43EI for IMAC. Does anyone know of this application with this equipment?
RE: Hanger 9 Extra 260 with Fuji 43 EI
I've seen that engine and it's not powerful enough. I'd rather go for a good DA 50. Gee... u see... the height of my flying site is not helpful at all regarding engine performance (8500+ ft OSL). Though it could be of use for u since if it works here, it'll work everywhere...!!!
CA
I would agree, that engine won't put out nearly enough power. I have a flying buddy that put the 80cc twin into a Lanier Yak thinking it was going to rip. Sadly it is a toatal pig. Even worse is that the engine is going to make the airplane too heavy as well. I too would go with the DA 50 or even a ZDZ 50 and keep the setup as light as possible. Single RX battery amd light weight components everywhere. Target weight IMO should be around 14 to 14.5 lbs.
Shawn
http://rcblimpproductions.com/
Shawn
My Feedback: (190)
I have the H9 260 with a DA 50 on it. Her dry weight is 14 lbs 11 ozs. Unlimited verical with a 23 x 8 prop. I have JR 8411s on elev and ali, a 8611 on the rudder, and a Fut 9001 on the throttle. Two Fromeco 2400 li-ion batteries. I would not trade or sell for anything. Go luck with yours. My field elevation is around 1500 msl.
My Feedback: (44)
Hi Shawn my experience with the ZDZ50NG has been very positive and it has been flying several Great Planes Patty W Extras which are a bit heavy --Recently one of our locals came out to the field with a DA50 equippted Yak (the over priced one ) by what ever his name is from South of the border..I had WAY more power on the vertical and running a less expensive 22-8 than the DA50 equippted Yak
My Feedback: (26)
MO
I love this plan, great fun! I agree with the above statements concerning the DA 50. This a great combo even with a 22x10 break in prop. More than enough power for up lines and nice controlled down lines.
Some guys have had problems with the landing gear de-laminating. No problems here- our run way is asphalt.
