JR 10SXII programing.
My Feedback: (506)
I had a 10SXII and now have a 10X.
The 10X manual is very similar to the 10SXII manual - the majority of the function codes are identical and work similarly. There's certainly enough info there to get you started.
The programming differences I remember between the two radios are as follows:
That's all I remember. Hope it helps.
- Code 12 - Travel - adjustments can be made to both servo directions at the same time, or can me dine seperately
- Code 13 - D/R & Expo - Same thing as Code 12.
- Code 18 - Throttle curve - the SXII has this function, its buried 3 pages deep into the Code 13 (D/R & Expo) menu. No throttle servo hold feature either - shut the engine down before you start adjusting!
- Code 23 - FM Rate - you have to manually assign your dual rate/expo settings to flight modes. The 10X does this automatically, so no more Code 23.
- Code 31 - Snaproll - on the SXII the direction of the snap is always programmed in software. On the 10X snap directions are determined by the switches on the back of the TX unless you're using flight modes. I don't know why they did this.
- Code 82 - Trim offsets - the 10X has digital trims, so this function doesn't exist anymore.
- Misc? The screen contrast is adjusted via a pot on the side of he SXII, and through software on the 10X
I know I am not the only person that uses the 10SXII.
No I was hoping that someone would be nice enough to copy the 10SXII . I have one on order with Horizon,but that could take months.
