Go Back  RCU Forums > RC Airplanes > IMAC
 Adjusting engine thrust >
IMAC Discuss IMAC style aerobatics in here
Old 06-10-2007 | 01:15 PM
Default Adjusting engine thrust
I would like to mount an engine to firewall in inverted position with head about 8 o-clock.
If the engine thrust needs to be corrected I am not sure how to properly do this because the mounting bolts are then not straight up and down with the fuselage. Any suggestions? Thanks.
Old 06-10-2007 | 03:22 PM
Default RE: Adjusting engine thrust
Just the obvious I'm afraid. Different size shims under the mounting bolts.
