Gasoline engine plumbing
I am getting ready to assemble my first gas powered plane (a 3W fun Xtra).
What is the recommended method for plumbing the plane? Are you using a 3 line tank and fuel dots? What about a sullivan/dubro fueler?
Leonard Decarlo
Tyler, TX USA
Leonard Decarlo
Tyler, TX USA
All you need to do is run a two line system.
The line to the carb needs a T on it to a fuel dot or something similiar. You wont flood the motor when fueling because your carb is a pump and no fuel will go that way till the motor is running.
My Feedback: (16)
GA
Get the MIRACLE FUELER. Mounts to the side of your fuselage with a jam nut.
http://www.qualityrcproducts.com/miraclefueler.html
Like a previous poster said:
A T-connection in the fuel line to the carb, with a fuel dot to round it off nicely.
One single vent tube in the tank, going up from the bottom to prevent syphoning action.
Originally posted by pe reivers
............One single vent tube in the tank, going up from the bottom to prevent syphoning action.
Thanks.........Mark
