Super bee
Super bee
Question reguarding my application can a super bee axis be offset, instead of glow plug at 0 degrees can it be set to 45 degrees ?
second how tolerable are the thermocouples can they be inserted more then 1/16 or 2mm and if the 1/16 tip is broken off can it still be used ?
Thank you.
Thank you.
My Feedback: (10)
FL
RE: Super bee
Hello:
Glow plug orientation for gas start turbines may be moved to the 2 o'clock or 10 o'clock position. Never at the 6 o'clock due to the gas possibly cooling the element.
Thermo couple if determined dead at the tip must be replaced. Insertion depth into the nozzle is not recommended to be deeper than 1/16 inch.
Thanks for the questions,
Eric Clapp
managing director
Eric Clapp
managing director
