Which glow plug for Super Bee and Question regarding plug connector
My Feedback: (28)
Super Bee normally starts on gas immediately and runs great. However, having trouble getting Super Bee to start after plug burnt out. Forgot which plug I was using and when I tried 2 OS 8 (which was only ones I had at the time) turbine would not start. Noticed that element would not glow the entire length of the wire when pulled out – would not glow on the half from where grounded to top of pulled out loop.
I have heard that McCoy 9 maybe should be used???? Any experience with the Dreamworks Dura-Plug? I note on their web site they indicate issues with JetCat turbines.
Also having problem with plug connector. Because of the angle I have to use needle nose pliers to grab when pulling on the spring loaded boot and am distorting the end to the point that spring will not function. Can a remote head lock type connector be used vs the spring loaded boot connector?
Thanks in advance.
Thanks in advance.
RE: Which glow plug for Super Bee and Question regarding plug connector
Hello dblades
McCoy 9 or Rossi 8 are the most recommended, for the Rossi you need to increase the glow plug setting 3-4 points
Remember to pull out the element a lot
You can use any type of glow connector as long as it is good quality and guaranties a solid connection
Regards
Regards
