P120 and Flight Works Pump
Is it OK to use a Flight Works Pump with a P120. This pump was used with my simjet 2300 turbine, I am having pump problems with my jetcat pump.
RE: P120 and Flight Works Pump
If I were you I would stick with the Jet cat pump , I have been using them and no problems so far , I am not saying trere are no problems , just I have not experienced any
Well it does work, but I don't get the full RPM. I only get 104,000 RPM at full trottle when I should be getting 123,000. I think this is from the flightworks pump being too small, the model is 300B. Well I will just go and buy a new jetcat pump. Thanks for all your advice.
the 300b should work, hold the Manual key on the GSU and slowly advance to full thrust and continue to hold Manual, this will reset the parameters and allow you to reach full RPM.
I tried that about 6 times as I read this on some old posts. It still did not work. Pump voltage on GSU read 3.80 volts, and would not go any higher. I think the 400-B would be better like you said. I have made contact with Dreamworks for new jetcat pump.
