JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Quick Disconnect.
Old 11-12-2012 | 08:55 PM
Default Quick Disconnect.
Hy guys.
My Jetcat came with these quick disconnect fittings. Could it be use in the fuel lines, or just starting gas only? Thanks.
Old 11-14-2012 | 07:41 AM
Carsten Groen's Avatar
Default RE: Quick Disconnect.
I use these for all my jets for fueling, never had any problems
Old 11-14-2012 | 09:16 AM
Thank you for the info. I plan to use these in the fuel system for my helicopter since the mechanic may have to be remove for maintenance periodically, and it is much easier to disconnect these in tight space than Festo.
