Error, temp sens cable amp on gsu?
I had this error msg. Upon startup of my p 60se. Called jet cat and they said e.g.t. Is bad, they sent me a new one sence the motor has only 4 hrs on it. Before accually installing it I just plugged it into the p.c board on turbine and tried ca liberating, same msg. Came up, temp sens cable amp. Tried new data cable and same thing. A friend of mine Dave fusinato asked john redman about this at best in the west ( I couldn't make it ) and john said probably just new sensor got damage in shipment to me. I've heard of e.c.u. Possibly the problem after replacing many e.g.t. Sensors and cables from other posts here on rcu but john said cannot be e.c.u. And to call for another replacement sensor. Has anyone heard of other components going bad that would give that type of error msg ???
