P200 SX at 105500RPM
Hi,
I've a problem with my P200SX, turbine run time 37minute.
Yestersay first start of the year, turbine is in a Mk66 Hawk from Tomahawk design.
Fuel line is tank to GBR air trap tygon 6mm, GBR to pump 6 to 4 mm, pump to P200SX, 4mm.
I've nothing change since last year, and last year turbine run perfectly.
This is the last run GSU parameters:
max RPM: 105500
max temp: 544°
max pump voltage: 6,2v
I've tried to increase RPM with the manual button on GSU when throttle is at maximum, but nothing change.
Any idea?
Best Regards.
max RPM: 105500
max temp: 544°
Any idea?
Best Regards.
Ok. The only other thing I can think of right away is maybe your pump has reached the limit for a P-200SX. I don't know if 6.2v is the limit or not. Maybe somebody else can help.
The PID reset doesn't always work - which is what you're trying to do. If you have another pump, it would be worth a try. Otherwise a call to JetCat, Germany would be in order.
Hi, max pump voltage is 6,2v, I will try another pump.
Best Regards
