error code "LoRpmPmp"
Hi,
My jetcat 140rx had a flameout in the end of the flight, when it was already in idle.
I used a kerosene that probably was contaminated with water.
The error code is "lorpmpmp" , what does it mean?
Ricardo Forte
Ricardo Forte
NY
It means the pump was the cause of the flame out. Have you had your pump software updated to latest version? Your ecu should also be flashed to latest software. If you had water in the fuel you would see white smoke after flame out. If no smoke and clean shut down I highly recommend you contact JetCat for the latest software.
