P140rx fuel pump leaking
Hi,
I bought a new P140rx in 2013 and installed it in my ultra flash last year, its worked brilliantly but i noticed a little fuel under the pump a couple of times, well today it got a lot worse and on start up there was a little smoke coming from the pump where the plug goes in the end, i shut it down then had a good look, i loosened the two grub screws and slid the case off and its all soaked in fuel including all the electrics, any advice as to what i can do? or do i need to send it for repair or exchange?
Regards
Martin m
Regards
Martin m
