Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
P100rx problem first start of the day, fail with "low temp" >
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 10-14-2015 | 09:32 AM
Default P100rx problem first start of the day, fail with "low temp"
Hi pilots!
i have problem with my p100, the first start of the day (could start) the turbine come to 120šc and after this acelerate and donīt start, appear message on gsu "low temp", i need to remove the cover of engine and clean the fuselage because on cone of turbine stay a lot of kerosene, after this, on second try to start, the turbine run okay, with a little flames on startup, but, the first start of the every day of flight i have the same problem, can you guys help me to change aceleration curve or other parameter to resolve this issue , i donīt know why i enter on hide menus of my ECU, Version jet tronic 10.2T fuelpump v6.7 eng connected v7.7
thanks friends.
