V10 ECU RPM2 Output
GA
V10 ECU RPM2 Output
The V10 ECU has a connector labeled RPM2. Is this an output? What is the nature of the signal? Should I be able to detect a signal anytime the turbine is spinning?
Thanks for any help,
Gary
Gary
GA
Thanks for the reply. That's the answer I got from Jetcat Americas support. It's an input from the gearbox sensor measuring prop RPM for the turboprop engine.
Gary
Gary
