Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
JetCat P-70 Outer Shell Dent and Starter Damage >
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 01-18-2019 | 09:08 AM
Default JetCat P-70 Outer Shell Dent and Starter Damage
Hello Matt,
I acquired a JetCat P-70 and was wondering if the engine can still be serviced or if service to this engine has stopped since it went out of production 12 years ago. The outer housing of the engine has a few dents in it and the starter motor assembly/plastic guard is damaged. The internal engine components are fine and the engine spins freely and runs great. Although I have to start the engine with air since the starter motor does not align properly. The total run time on the engine is 7 hours.
Thank you very much for your help,
Marcel Achtenhagen
