JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
jetcat 4.9 ecu
Old 05-13-2019 | 02:33 PM
Default jetcat 4.9 ecu
trying to set this engine up without using the aux channel to run the engine...but it doesn't seam to want to let me..l tried not plugging in the channel as the book says...an tried to see it l could turn it off in the limits menu but it says it is already off...am l trying to do something l can't do..
Old 05-13-2019 | 09:07 PM
So when you do a learn RC it still asks for the Aux switch to be moved? Does it say Inhibit or not used in the limit menu?
Dave
Old 05-14-2019 | 12:21 AM
still ask me in learn rc..doesn't give an option to change
Old 05-14-2019 | 10:24 AM
In limits menu if you hold change value and try plus or minus does the Aux channel option change?
Old 05-14-2019 | 02:58 PM
says l can't change the valve
Old 05-14-2019 | 03:00 PM
figure I'm doing something wrong..some how at one point a got into a whole of different menu but can't get or remember how l did it
Old 05-14-2019 | 09:09 PM
Everything switched on, hold down select menu key, use the right arrow (+) key to screw through to turbine limits. Let go of buttons. Now just use the right arrow to scroll to Aux channel. Press and hold the change value key and using left or right arrow change to inhibit
You ECU will be on the change over of chip, the very late Letter numbers auto detected if you did not plug in the Aux channel just like the latest ECU’s now
Old 05-17-2019 | 01:45 PM
Thanks Dave for the help got it turned off... l was trying to change the wrong limit in the wrong menu after going through it more..thanks again happy flying Jay
