P20 sx low temp @ start-up
MI
Help needed!!!!!!
Pump or valve block problem?????
How can I check pump off model using external fuel supply & separate battery? ?????
P20 has 7 hours TT.
Pump runs interment.
Can valve body cause pump not to run if valve is defective???????
Dave
P20 has 7 hours TT.
Dave
Dave
you cant, but you just disconnect from turbine and run pump in test functions. You can hold change value and scroll + or - to increase or decrease the flow rate. Valve needs to be in the system and if it flows it works!
MI
URL 1 .400
I didn't Know about burner valve test & fuel valve/ thanks. Having problem w start lately, thought it was fuel valve because no fuel came out w purge. Valve probably ok. Suspect pump intermittent.
Been flying it in Scimitar for 3yrs no problems except static electricity in desert.
Ordered new pump today, hope that's it.
Dave
Dave
