Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
Replacing external Temp. probe JC 160 >
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 11-13-2021 | 09:27 AM
My Feedback: (12)
Default Replacing external Temp. probe JC 160
Anything special to know when changing out external temp probe on JC 160?
Thanks in advance for any pointers to look for....
Old 11-13-2021 | 01:26 PM
No. Use the original plastic mount (there is a single screw through the pcb) Unscrew the M3 screw holding the rear of the probe and pull the plastic cover up.
If you don’t have a new rear tag, squeezing it gently and it will opening it enough to pull the wire out.
Old 11-13-2021 | 04:26 PM
My Feedback: (12)
