JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Tail Pipe Question
Old 04-17-2004 | 08:49 PM
Banned
My Feedback: (67)
Default Tail Pipe Question
# 1 Will a STRAIGHT pipe for a P-120 work for a P-160?
# 2 Will a STRAIGHT pipe for a P-80 work for a P-120 ?
Thanks............. Johnny Hernandez
Old 04-17-2004 | 09:52 PM
mr_matt's Avatar
My Feedback: (10)
Default RE: Tail Pipe Question
I think so. I ran the same pipe in a Bandit with a P-80, a P-120 and a P-160.
Old 04-18-2004 | 11:15 AM
Banned
My Feedback: (67)
Damn Matt !!!! are you sure?
Well if thats the case I'm good to go than, Thanks a lot once again.
Johnny Hernandez
Old 04-18-2004 | 12:19 PM
mr_matt's Avatar
My Feedback: (10)
YEah that is what I ran, the pipe was a standard BVM.
There are probabaly optimizations for each, but I never bothered. It is not cut and dried. I say try what you have.
As Eddie Weeks has said, if the pipe is off, it will either make temps lower (with less thrust) or higher (more thrust) As long as the temps in the final installation look OK, I say it is OK.
But I am not an expert. I know BVM has made a bigger bypass for a P-160, but I have not seen one. Tam might have some input here as well.
Good luck,
Old 04-18-2004 | 08:51 PM
Banned
My Feedback: (67)
thanks Matt, I dont have to worry about the bypass issues cause I dont have them on either Jet so I'll try it and if it works fine if it doesnt I'll get a couple of pipes
Take care man .............. Johnny
Old 04-25-2004 | 10:25 PM
Banned
My Feedback: (67)
Matt by the way It works just fine with the P-160 thank you . Thats the pipe i have on the big 16 and it seems to be working fine.
Now I have an AD F-16 that was flying according to its previous owner with a P-80 and I'm going with a P-120, very small pipe you think that'll work ?
Johnny Hernandez
Old 04-26-2004 | 07:24 AM
mr_matt's Avatar
My Feedback: (10)
If the temps are OK, it is probabaly OK.
Like I said I used the same pipe with a P-80, P-120 and P-160. BUt that was wiyh a bypass. Give it a try and just watch the temps.
