JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
help
Old 05-26-2004 | 02:40 PM
Banned
My Feedback: (67)
Default help
I know JetCat is moving and all, I had left a message but no response please. Anyway I'm trying to set up one of my twins and this particular one has a pair of 120's How do I start these turbines together ? or is there some gizmo that I need to buy to get them running
Thanks............... johnny hernandez
Old 05-26-2004 | 03:13 PM
Default RE: help
Hey Johnny - while you are waiting for an official response, this might help: see page 52 of the V5.0 manual : you need to set the startup mode of the two engines differently.
If using single channel, put one in sequence mode and one in immediate mode ; moving the trim up should start the engine that is in immediate mode ; moving the stick up should start the 2nd engine.
If you are using 2 channel mode then you set one engine to "sequence" mode and the other to "throttle max" mode ; That way you start one with the aux control, the other with the trim & stick transition.
The manual is here: http://jetcatusa.sitewavesonline.net...alV4.9_5.0.pdf
Gordon
Old 05-26-2004 | 11:11 PM
Banned
My Feedback: (67)
Default RE: help
Thanks Gordon,
Is Jetcat assisting anyone ?? Is there an easier way to do this ?? is there a special Box or some kind of electronic item that would make things easier?
Thanks for your assistance I will try your reply as well.
Old 05-27-2004 | 08:27 AM
Default RE: help
Y the two input together and start both simultaneously!
Old 05-27-2004 | 09:04 AM
Banned
My Feedback: (67)
Default RE: help
Ok I'll try both ways and see which one makes life easier
thanks again guys....................... Johnny Hernandez
