JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
p60 question
Old 04-22-2006 | 06:32 AM
Default p60 question
I have a new p60 purchased at Toledo R. C. show. Have completed 4 short runs on bench. All is ok except, in the info menue I do not get a report on the second parameter fuel flow. Is this normal???????
Also I have set my ecu for single channel operation. Is this detremental in any way to using the aux. channel????
Thanx for your help
Old 04-24-2006 | 12:05 AM
mr_matt's Avatar
My Feedback: (10)
Default RE: p60 question
ORIGINAL: david101
Thanx for your help
Hi David,
Can you tell me which parameter on the Info menu you are not seeing? Sorry I can't figure it out for you now.
As for single channel operation (i.e. not using Aux), this has no detrimental affect on the turbine. However, I would suggest that before shutdown, you run the turbine up to about 60,000 RPM for about 5 seconds, then immediately shut it down. This helps cool the bearings and is done automatically during 2 channel normal shutdown.
Hope that helps,
Old 04-25-2006 | 05:03 AM
Mr Matt
In the info menue, I see the fuel flow ml/min and the value shown after running is 0.0. Should a numeric value be shown here????
Dave
Old 04-25-2006 | 09:33 AM
mr_matt's Avatar
My Feedback: (10)
Hi David,
That fuel rate parameter is live so it will read "0" when the turbine is not running. Hope this helps.
Regards,
Old 04-26-2006 | 05:26 AM
Mr Matt
Message is loud & clear. Thanx for info as I thought the info menue was static.
All is well then.
Thanx again.
Dave
