Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
 Basic Ques. abt AUX mode operation >
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 07-08-2006 | 01:20 AM
Ragz's Avatar
Default Basic Ques. abt AUX mode operation
If I want to save a channel on the rx. and start the engine by cycling the sticks, is it enough to just ignore the aux lead? Or do I need to get into the menu and instruct the ECU for NON-AUX operation (if any such mode exists). I have done bench running with no aux channel lead connected and works ok..engine starts with trim and stick cycling method. just want to be sure if ECU needs to be re-programmed.
Old 07-08-2006 | 08:58 AM
mr_matt's Avatar
My Feedback: (10)
Default RE: Basic Ques. abt AUX mode operation
Hi Anurag,
If it is a version 4.9R or later ECU, you just unplug the AUX connector from the receiver and relearn RC, the single channel mode is automatically detected.
Hoep that helps,
Old 07-10-2006 | 10:29 AM
Ragz's Avatar
Its an old 4.00L
Old 07-20-2006 | 07:37 PM
On the old 4.0 ECU's, the only way to disable the AUX channel is through the menu which can be accessed through the GSU.
Jason Burg / JetCat USA / Technician
Old 07-21-2006 | 12:32 AM
Ragz's Avatar
Thanks Jason, I have disabled it.
