JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
p70 max thrust
Old 07-31-2006 | 02:33 AM
Ragz's Avatar
Default p70 max thrust
Whats the max thrust a p70 produces? I have read 17.5lbs on jetcat usa site..where as some other sites claim 16.5lbs at 123k.
Old 07-31-2006 | 02:58 PM
mr_matt's Avatar
My Feedback: (10)
Default RE: p70 max thrust
Hi Anurag,
Well as you can imagine this is a tough question. The conversions for temperature and pressure and humidity are not simple.
We have recently measured P-70's at 16.6 pounds thrust on a 104 F (40 C) day. In our experience this would be around 19 pounds, or a bit more, on so called Standard Temperature and Pressure day.
We have also measured other vendors motors in an attempt to corroborate this and other parameters (fuel consumption, etc). If these other turbines put out their rated thrust at STP, then the P-70 would be putting out over 19.6 pounds at STP, again based on how we measured other turbines.
Sorry for such a complex answer, but this thrust number is hot topic right now and we have to be clinical in our answers. As Jason Burg said, the P-70s are loafing at 123K RPM and on tear down some with dozens of hours run time are nearly indestinguishable from new ones .
Old 07-31-2006 | 06:25 PM
You might want to read what i wrote about the P-70 in this recent thread....[link=http://www.rcuniverse.com/forum/m_4563186/tm.htm].... i hope that helps and doesnt take you too far off course.....
Jason Burg / JetCat USA / Technician
