Onboard propane tank orientation
ON, CANADA
In my JetCat manual it says that the onboard propane tank can be mounted vertically or horizontally so long as the "offset nipple" is toward the top. What offset nipple? My little tank is like a mini aerosal can with the "nipple" in the centre of one end...
I was just going to lay it down horizontally, that's ok right ?
Marcus
Marcus
My Feedback: (10)
RE: Onboard propane tank orientation
Hi Marcus,
That manual is a bit out of date. You see the older tanks had the offset nipple, which BARELY allowed a more horizontal installation. You do not want liquid starting gas anywhere near that nipple. With these new tanks, you should install much more to vertical, maybe within 30 degrees of vertical at most.
Regards,
Regards,
ON, CANADA
Darn it, the motor install is largely complete now (just wiring to go) and the bottle is laying flat horizontal with no place to re-orientate....
I could start the motor with the vehicle lifted over I guess [?] Liquid in the lines will damage the system or just make the start unreliable Matt ?
I could attach it to one of the forward rollcage uprights but it will then be in front of the intake albeit to one side. Is that going to have a huge effect on the motor efficiency ?
As you see, I don't have much real estate to work with. Darn it ! []
My Feedback: (10)
You want to get some safety wire on the pump nipples, especially the inlet. Also, what kind of hose are you running from the UAT to the pump?
You can tilt the bottle and that will help. I had a totally horizontal tank in my Phantom, and I had to raise the nose to get a clean start until I tilted it up. You just stand the chance of injecting liquid starting gas and this messes up the starting sequence. No real chance of damage but missed starts are something you want to avoid in order to minimize dry running of the bearings.
You also need to tie that vent line (and the other loose items) down or it will get sucked into the turbine. You really need a FOD screen pretty bad!!
What is this model??
Oh and Bob could not really get the software do do exactly what you wanted (a real time replay) Sorry.
ON, CANADA
I'm tempted to agree with you Dave. I've already removed the can and am seriously considering using it externally. I'm a bit honked at the manual being an old version to tell the truth. noth jetCat's fault though.... I bought the motor from a UK Distributor and when I got home I discovered there was no manual in the box. I thought the shop were being ok and sent me the manual I have here but it just looks like they stuffed an older version in the mail to shut me up []
I would use a Kero start but I don't have the headroom between the motor and bodyshell to fit one in. It sits about an inch proud I believe ?
ON, CANADA
Picking up the FOD screen from my LHS tomorrow, it came from Graupner (Germany) in 3 days, not too bad.
It's pretty well known here in the UK R/C scene, been in a national magazine etc.
[link=http://www.mkeeler.com/models/marjet/]Clickme[/link]
OR
I always laded the tank down, it was 2' from the turbine worked fine, by the way "they said" not to use a FOD screen in the beginning.
Darryl
Darryl
My Feedback: (10)
Hi Markus,
Cool model, good luck with it.
On that inlet line, what you have might work, although I did not think pure silicone worked well with kerosene. There is a lot of suction in that line so I might worry about it collapsing, you can always try it and find out, though that might be hard to troubleshoot.
We normally run 6 mm line from that UAT nipple to the pump, then either run a 6 to 4 brass adapter, or put a very short piece of 4 mm on the pump nipple, put the 6 mm over that and safety wire the whole thing. See the thing you are trying to avoid are air leaks on that suction side. If they are small, they displace a lot of fuel and you will not get full power, if they are big they will shut the turbine down. Many leaks only show up at very high power and of course since they are on the suction side they leave no residue to help you track them down.
Good luck,
Good luck,
ON, CANADA
I picked up some Kerosene fuel piping at the LHS today when I collected the FOD guard. You are right of course Matt, the LHS confirmed that the silicone piping would break down with kerosene. The piping I have looks like silicone but is designed for Petrol & diesel.
ON, CANADA
I made the cable up Matt. It is a 6 cable pin-to-pin connection. That's ok right ?
I haven't run the motor up yet although I have applied power to the ECU & Radio during power testing. The ECU emmits a little tune on power up, that's normal and a sign of all being ok?
Thanks Matt
Thanks Matt
ON, CANADA
Matt, with your reference to my manual being out of date, I downloaded the latest manual from your site and it also says that that onboard propane tank has an offset nipple [X(]
The starting gas tank can be mounted vertically or slightly horizontally. Whether the tank is mounted upright or slightly on its side, the nipple must always be towards the top. This will limit the amount of liquid propane entering the turbine during startup. After every flying session, open the release valve to empty the tank, before storing the model. Perform this procedure in a safe area.
My Feedback: (10)
Hi Marcus,
It looks like the little schematic shows an offset nipple, but the wording seemed clear to me, sorry for any confusion, I will get that into the next round of updates.
If you made the cable up and you heard those beeps it should be fine.
Good luck,
Good luck,
ON, CANADA
Ah, so you mean vertcial or 'close to'. Gotcha... I've removed the tank for now and will use it externally for testing. Perhaps I'll have a re-shuffle in the future and attempt to get it back onboard. Sure would be nice to have the car start without assistance, for demos, which I'm sure I'll be giving at local clubs.
My Feedback: (10)
Hello again,
My Stingray has the tank about 25 degrees from horizontal and it works fine. You just want to avoid having liquid propane/butane mixture near the nipple. It does not take a WHOLE lot of mounting angle to assure this, on a partial fill.
Regards,
Regards,
ORIGINAL: mr_matt
Cool looking toy BTW !!
Gordon
PS Matt - great catch on the tubing and the non-std cable - those eagle eyes of yours are working overtime !
Hey Matt - since this is an off-road buggy ... what's the likely effect of rough rides on the turbine longevity ?
Based on my experience of doing lots of snaps etc with my Bobcat, I know that the gyroscopic effects mean that the engine being banged from side to side can lead to premature bearing wear, eventual compressor wheel rubbing, etc. So, does Marcus need to be careful to limit the terrain type he plays on, to minimize rough rides ?
Gordon
Gordon
My Feedback: (10)
ORIGINAL: Gordon Mc
Gordon
Gordon
ON, CANADA
This is an off-road car, but it will never see dirt. It's made for speed runs on smooth asphalt. The wheels are oversized units which will furth smooth the ride.
I do expect some issues with fuel airation although hopefully the BVM will supress it.
