P80 Burp
I just tried my P80 today with my ECU that was upgraded this winter with the new version 5.10H. And when I go from Idle to full throttle, its seems OK, BUT from about 90 000 rpm to full throttle. It BURP for 2 seconds around 100 000 rpm, is this a problem with the new version of the ecu. Is there to much fuel being pumped in, it is safe to fly. I will try to get a video and give Bob a call Monday, but I wanted to see if anyone have any clue what is happening. P80 serial# 965B the combustion chamber and bearing changed two years ago.
What i know about compressor stall is the compressor can not push enough air through the diffuser, and with enough compression, it cavitates and can not push any more air for a millisecond and then the process starts again for a short period. Basically I think it is due to too fast ramping up. So the cure is to increase the ramping time in the ECU
Thank! Guys! I will see if Mr Matt has something to say about it, and I will call Bob tomorrow, because its a holiday in the U.S. today. If anyone has others hint on what to do? Please help?
Thanks Guys! I gave Bob a call and as you said its was Compressor stall. The programming in the new version was to aggressive for my old P80, so Bob ran me through some setting in the ECU. And I tried it out tonight and everything is is OK.
Hello
I´ll have exactly the same problem with a P-80(old) and a brand new Ecu.How did you change the settings
Regards Niclas
[email protected]
Regards Niclas
[email protected]
I´ll talked to Markus Zipperer at JetCat and he helped me tru the codes and other thing on the GSU that not normally could be changed into the ECU and now it workes great.
Hi kelly vallee ,
I assume from your post the fix you say is easy, can you please post the fix here so everyone can see it, so we don't have to bother Bob..?
