extensions
My Feedback: (47)
Not sure of JetCat's official stance on this, but I've made ECU battery cables up to 24" long (using 16 gauge wire) and throttle and solenoid extensions up to 18" (using heavy duty servo wire, 22 gauge, I think). Done this many times over the years with no problems.
Barry
Barry
My Feedback: (10)
ORIGINAL: DelGatoGrande
...on a p-120 i need to make the batery cable 80cm and the throtle and aux extensions 70cm long coming off a powerbox royal..
any bad with that? thanx in advance!
Sorry for the late reply! Use high quality connectors (I use Deans powerpole or multiplex) and heavy guage wire (at least 13 guage) and the ECU extension is fine. If you are using a kero ignitor, make especially sure you use large guage wire and high quality connectors
Any high quality servo extension is fine for the throttle and aux connections.
Regards,
