JetCat GPS Unit
Hi,
I'm thinking about getting JetCat GPS unit, but I'm
not sure if this device stores only max achieved values or full flight data as a function of time. I've emailed Bob Wilcox, but he is probably at the one of the jet events because he hasn't replayed yet.
I'm looking for the sample flight data file downloaded from ECU with GPS unit connected? Can anyone of you send me such file????
Regards
Marcin
Regards
Marcin
Bringing to life an old thread here...:-)
I'm about to mount my JetCat ECU v6 and GPS unit (new "alien-eye style"), and have some q's:
[ul][*] Do the ECU store these data even after power-off, or do I need to transfer them to PC at the field?[*] How long recording time will the ECU be able to store?[*] How do I get the data over to the computer? Do it exist some kind of serial or USB interface/software? Aprox price?[*] I read something about it measuring G's? Do it have a built in G-meter?[*] I'm mounting this equipment in a CompARF Eurosport. Should I take any special precautions to placement of the GPS unit, or will it work wherever in the model, as long as it's facing upwards?
[/ul]
Thanks a lot in advance!!
[/ul]
My Feedback: (10)
Hello,
No you need the a PC or netbook at the field.
Latest version about 20 minutes. Older versions maybe 8?
Yes it is a serial device. Some third party USB serial converters will work. US$125
Yes it derives G forces from GPS data (2nd derivative of GPS position), not sure of the accuracy of such a system, especially with changes in altitude. In level flight it might not be too bad.
Looking towards the sky, the frequencies are at around 1.6 GHz, so treat the antenna like you would a SS receiver and keep it pointed upward.
Regards,
Regards,
