Motor mount bolt pattern
A friend is building a new jet and wants to do first flights with an IC engine BUT with the idea of putting in a JetCat P120 or P160 in it once the design is proven.
This is going to be a trainer for a new even larger scale jet.
He wants to drill the fuse for the JetCat and then build an IC mount.
Any help appreciated.
Rcbart
Rcbart
Yup, he doesn't have a turbine, nore one to look at. The idea is to built an IC motor mount unit that will attach TO the screw holes where a JetCat WOULD mount - when he gets to buying one.
ie. he would 'match' the drill pattern so as to have the plane 'JetCat ready', when he buys one.
My Feedback: (10)
Hi Bart,
I completely dropped this thread. I checked with the shop and there are no drawings of the mount with the holes. I guess I could try to measure one, but candidly I am not very familiar with this mount as I have never used it.
I am not sure how accurate my measurements would be, but I can try to get them tonight
My Feedback: (10)
Well I tried to measure the mounts, but it is difficult, as the shape of the mount is somewhat affected by whether the motor is bolted into or not.
As best I can tell, the dimensions of the bolt pattern are
6 5/32 X 2 3/32 inches. The longer dimension is across the turbine, in other words parallel to the wingspan.
This is very rough and will likely require slotting of the holes, so be forewarned!
I should be getting an engine back from Jetcat in the next couple of days - if it helps, I could temporarily put the Jetcat mount around that engine & take some measurements before putting the engine back in the BVM mounts that I'm using in the aircraft.
Lemme know if you would like me to do that. Also, rcbart mentions using a P120 or a P160 - are the cans exactly the same diameter, so that a measurement based on just one of these engines will be sufficient ?
Gordon
Where Matt gets 6 5/32", I get:
Rear : 155mm = approx 6 3/32"
Front: 154mm = approx 6 1/16"
Where Matt gets 2 3/32", I get
54mm = approx 2 1/8"
This was with the clamp fully tightened around the case, and the measurements were taken with two different calipers just to double-check on the meausrement.
The above measurements differ form Matt's "rough" measurments by only a millimeter or two, so no big deal there - as Matt says. you can always slot the aluminum engine mount very slightly to account for minor tolerance variations.
Later,
Gordon
Thanks all, I will give this to the gentleman on Saturday, he is back on this projectt - he had one to finish for an upcoming meet- so might want to start this tomorrow.
Regards
Bart
Regards
Bart
As I suspected, he had the IC motor mount built, waiting for the base size. Attached is the picture. The pencil is sitting on the fueld tank/thorttle servo tray, the circle at the right is the engine firewall while the unfinished plate at the bottom is to mount to the plane.
Thanks again.
Rcbart
Thanks again.
Rcbart
