Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
 P-70 throttle response problem >
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 05-09-2008 | 02:31 PM
My Feedback: (14)
Default P-70 throttle response problem
Matt,
I have a friend who's not very jet knowledgable who's got a P-70. He's complaining that the engine has no throttle response between idle and approximately half throttle, then at about half throttle it suddenly jumps to about mid thrust. I haven't had a chance to look at the engine or radio set-up yet, but thought I'd ask before I go over and see if I can help him, thought I'd ask a few questions?
Is there any known issues with slow throttle response in P-70's?
Think this is an engine set-up problem or a radio set-up problem?
Ever heard of anyone else that's had this kind of problem or had to use a throttle curve to get linear response?
Jerry Neuberger
Old 05-09-2008 | 03:17 PM
Default RE: P-70 throttle response problem
if the throttle is set linearly that's pretty much how it should respond, you don't start building significant thrust till over 1/2 stick.
Old 05-09-2008 | 07:36 PM
flyinfool1's Avatar
A spool-up time of 6-7 seconds from idle to full throttle is also normal.
I am starting to play with a throttle curve to get a more linear throttle response.
Old 05-10-2008 | 12:29 AM
dbarrym's Avatar
My Feedback: (47)
Hi Jerry -
Anyone here in SD that I might know?
The P-70 still has "old school" throttle response - like the old P120 in my Boomerang, about 5-7 second slam time on a good day. Your description sounds normal, you just have to get used to it, especially on approach.
I have a throttle curve set up in my 10X that works fairly well, I can show you how to set it up, or send you the pertinent specs if you know how to program a curve in your buddy's TX. PM me here or the club newsletter has my home phone listed.
Cheers -
Barry
Old 05-10-2008 | 12:50 PM
My Feedback: (14)
Hi Barry,
It's the P-70 Don G. has in his Bobcat. Don't recall for sure, but think he got the engine from Frank. It is one of the old school P-70's and I've flown it a couple times and thought the throttle response was pretty normal, but he keeps complaining about it. Think I'll go over one of these days and plug the GSU in during a run and watch the RPM to see what it's actually doing and if normal, I'll just program a positive curve in the throttle channel to make him happy.
Thanks all!
Old 05-14-2008 | 10:28 AM
mr_matt's Avatar
My Feedback: (10)
Hi Jerry,
A reverse expo curve can help, it provides more linear response through the mid range. I have a chart of what it looks like somewhere on this site, I will search for it later.
Sorry for the late reply, beyond busy at real work.
Old 05-14-2008 | 03:46 PM
My Feedback: (14)
Not a problem, Matt, especially since part of what's been keeping you busy was doing the SE conversion and bearings on my P-60 :&gt
Jerry
Old 05-14-2008 | 04:08 PM
ORIGINAL: s3nfo
Jerry
Matt isn't a hands on repair guy at JetCat, he's been optimized at non paid support where he is priceless
