Watchdog shutdowns
VA
During some aggressive taxi runs yesterday, we had 2 engine shutdowns which the GSU indicated as Watchdog. The ECU is mounted per on plywood with foam as recommended. No antistatic spray is used on wheels. The ECU was replaced, and another less aggressive taxi run was completed with no shutdowns. The manual indicates Watchdog shutdown is due to ESD. Does the Watchdog reading indicate a failed ECU? Is there an easy way to test the ECU that displayed the Watchdog? While replacing the ECU seems to have solved the problem, I am concerned that there may be another issue that just wasn’t encountered on the last taxi run. I would rather be sure the problem is solve before the plane goes into the air. Thanks for any advice.
My Feedback: (47)
What motor do you have? Are you using the anti-static fuel additive that BVM and Dreamworks sell?
There have been some isolated issues with the larger motors (P160/Titan and up) that have had issues with static-related shutdowns. A buddy with a Titan had this happen twice, but has had 60+ flights on the same airframe/engine with no issues since using the additive as described.
Good luck -
Barry
Good luck -
Barry
VA
Engine is a P120SE. Never used any anti static additives or supplies. Hundreds of flights with this setup in similar airframes and never had a Watchdog error. We did just switch from K1 kerosene to JP5.
